farmall 300 slips out of 5th gear
Sclem
.Farmall 300 only goes in 5th gear about half way & flies out of 5th gear when used. Goes in the other gears all the way & works good. Is the fork bent & needs replacing or what? Thank you for any information>
The stroke of 5th is less than the others, but the problem is probably one of three things.
Input shaft splines and 4th 5th slider gear splines are worn and tapered from continual rough grinding into 5th from 4th.
Worn or failed intermediate (pilot) bearing between input and output shafts (near the 4th 5th slider location)
Ball and spring on detent weak or broken.
All these repairs require removal of the trans top. The first two require a split of the tractor to get at the problem (IIRC).
The tractor usually does not have this issue because the TA allows starting in 5th TA then going to direct. Jim
Jim
We had the same problem with our 300 twice in ite lifetime. new fifth gear cogs fixed it up both times. kent
