SH Stg II Hydrlcs vs Lift all
Va Gasman
I had A Kelly loader on SH with Lift all belly pump. It went up very well and reached desireable height. I have changed the Loader to Sh W/stage II hydraulics and it raises 18" lower but has no delay. IS there less reservoir capacity on the Stage II ?
Did you check your fluid levels after working the loader? Make sure you maintain proper fluid capacity in the res. Justa thought jim.
If you've made sure the reservoir was full after running the loader up and down a couple of times, that would be the logical conclusion...
Unfortunately, my SH book are for the Stage I and doesn't include the live pump capacity.
When I'm out to the farm this weekend I'll try to remember to check Dad's Super MTA manual. I think the blocks are the same on the Stage II SH, SM, and SMTA.
