Removing torque tube 1939 H
Dave
10-20-2000 16:36:02
Are there just the four bolts inside and the two nuts outside to seperate the torque tube from the rear end. It seems loose but doesn't want to come apert. What is the trick? Thanks
The Red
10-21-2000 06:47:46
 Re: Removing torque tube 1939 H in reply to Dave, 10-20-2000 16:36:02
Dave you have me stumped. Are you speaking about the PTO?
clutch housing
10-21-2000 07:41:33
 Re: Re: Removing torque tube 1939 H in reply to The Red, 10-21-2000 06:47:46
I guess on farmalls it is called the clutch housing.I&T manual paragraph 278 says "Note: One bolt connecting clutch housing to main frame is accessible through seasonal disconnect opening." But I removed four bolts from inside and I see two studs and I removed two nuts from outside.
The Red
10-21-2000 07:51:00
 Re: Re: Re: Removing torque tube 1939 H in reply to clutch housing, 10-21-2000 07:41:33
Dave give Gary Biewer a call. He has dismantled a bunch of Hs through the years. My hunch is that the clutch housing is hanging up on one of two dowell pins. 218-937-5627.
