Super-A Hydraulic Problem S/N322212
I re-sealed my leaking touch control unit, it worked fine, but had a small leak at a spool valve. I purchased a re-seal kit, cleaned everything, and put it together.
All went well, I thought, and no leaks. But now it won"t un-load the hydraulic pump, the engine boggs down, and the touch control assembly starts to heat up. If I move the left or right control all is well as long as the piston is moving. When the piston stops moving the engine boggs down again. My shop manual is no help. It worked great when I got it. What did I do? Please Help.
