3020 diesel steering problems
susan4856
New User
i just got a jd 3020 diesel and there is something wrong with the power steering and it does not work so it makes it hard to steer with.
check your hydrolic fluid if its low make sure you look under the tractor at the rear rock shaft they like to leek there theres 2 seals that go bad pretty cheap fix takes about an hour
