coil question
RGT
10-19-2012 08:17:17
I have a farmall 100 which has been converted to a 12 volt. How do you check a coil to see if it is working ok? thanks
Jim Becker
10-19-2012 13:53:45
 Re: coil question in reply to RGT, 10-19-2012 08:17:17
They fire then the points open. In your test, the coil will fire when you unground the coil-to-distributor wire.
ken house
10-19-2012 13:34:25
turn switch on, and check to see if fire is going to switch side of coil, if it is turn switch off and go to next step.
remove coil wire, replace with a plug wire with a spark plug inserted into the end, ground the spark plug. remove the wire going from coil to distributor, from distributor, turn ignition switch on, strike wire to ground, spark plug should fire if coil is good.
spark plugs fire when points close.
old
10-19-2012 14:10:50
 Re: coil question in reply to ken house, 10-19-2012 13:34:25
You have it backwards. The coil fires when the points open not when the points close. If you think about it there is 4 lobes on the distributor shaft and when ever the points open the rotor lines up or should line up to a plug wire on the cap
ken house
10-19-2012 14:19:32
 Re: coil question in reply to old, 10-19-2012 14:10:50
when you get old, it is easy to get it wrong. thanks for correcting my answer.
old
10-19-2012 14:31:53
 Re: coil question in reply to ken house, 10-19-2012 14:19:32
Just one of those things that seem to work back wards of the norm
wisbaker
10-19-2012 09:25:00
Coils will however go bad it you convert a 6 volt system to 12 volt and don't add an external resistor to the ignition circuit on the coil supply side.
old
10-19-2012 12:37:04
 Re: coil question in reply to wisbaker, 10-19-2012 09:25:00
I have run many 6 volt coils on 12 volts and they have lasted for years, but the points do not last as long. But coils are not prone to going bad but points are
wayne in mn
10-19-2012 12:30:27
I must disagree; the POINTS will go bad quickly if no resistor is used on a 12 volt conversion. A resistor is not needed if the coil is designed for 12 volts (internally resisted).
old
10-19-2012 08:31:57
First thing to check is your points because of the points are bad the coil CANNOT work. Coils are almost bullet proof and do not go bad very often
