f-14 electric start
hi, I picked up a f-14 with an electric start setup. the tractor has been outside so long that both the starter ans generator are rusted tight. What is the best penatrating oil to soak this in. Also where can I get these rebuilt? Thank-you.
I don't know if I would soak them! But spray some PB on the nuts and bolts to see if you can open it up. Any good gen and starter shop should be able to rebuilt them. Make sure you tell them 6 volt. Electric start on an F-14 is hard to come by, I think F-20 eletric start is more common. oldiron29
If you need a starter we should have a few extra 12-14 starter motors around. Alderson tractor 641-624-2275 8-6 central time
