Jim, i was reading your instructions on how to time the M and I have 2 questions:
1. Once i get #1 to TDC, do I just rotate the rotor to the #1 position if its not already there?
2. You said to hook the light up to the lead on the side of the distributor, is that the wire going to the coil? and when i have the light hooked up, what do you mean by the distrbutor top should be turned?
Thanks for the help, as soon as I do this once i wont need help doing it again, the first time is always the hardest...thanks buddy, ~Anthony
