Farmall 350 starter
Allnightshifter2
08-24-2012 23:41:21
Just bought a 350, hit the starter and it fired right up, shut it off to talk about the tractor then went to restart it and starter relay just clicks, almost like starter was stuck in the out position so I put it in gear and rocked it a little but no help. Brand new battery and cable was getting hot to touch at the relay, could it be just a bad connection or something simple like that, I plan on going to pick it up this weekend and would rather drive it on trailer than winch it. So any thoughts on what I need to take with me would be appreciated.
John
Allnightshifter2
08-26-2012 04:24:45
 Re: Farmall 350 starter. Thanks in reply to Allnightshifter2, 08-24-2012 23:41:21
Thanks for all of yalls input. Should be an easy task now.
Owen Aaland
08-25-2012 20:30:19
 Re: Farmall 350 starter in reply to Allnightshifter2, 08-24-2012 23:41:21
Trying to rock a tractor with a TA doesn't work very well because with the TA clutch engaged you can only turn the engine in the normal direction. The TA will lock up when trying to turn the engine backwards. If you release the TA clutch you can only turn the engine backwards. The TA will free wheel going forwards.
jal-SD
08-25-2012 18:22:05
Don't forget that the only ground for the starter is where it bolts to the block. Make sure it is "clean, bright & tight" there, too; just like all the other 6V connections. (My $0.02 worth. jal-SD)
DeltaRed
08-25-2012 07:16:10
My SM has done that for 30 years.Sometimes it seems to do that every other time you start it.Other times it can go for months/years without hanging up.Carry a couple wrenches.Just loosen and wiggle,that solves the problem.
John T
08-25-2012 06:01:04
Your question:
"could it be just a bad connection or something simple like that"
If the cable gets real hot and the voltage drops drastically (lights would dim noticeably) thats a sign of heavy current draw (good connections) Id say its more likely NOT a bad conenction but more likely the starter is mechanically stuck/jammed or else its electrically shorted. If rocking the wheels in high gear dont help release it, you may have to loosen the starter mount bolts.
John T
Janicholson
08-25-2012 05:26:43
The others are correct. Rocking it requires High gear (5th) and direct drive, not TA back. The rocking is violent and results in engine movement sufficient to dislodge the drive. Loosening is directly effective.
At this point the drive should be replaced with a newer style that has a much smaller pull in spring, and which does not drive through that spring. It can be found on many sites, and, if the ring gear is usable (probable with a little careful filing to remove burrs) go for it. THe new drive is not expensive. Jim
gene bender
08-25-2012 04:26:39
Rockin sometime wont unstick them just loosen up the starter and listen for the click of the Bendix releasing.
Keith sullivan
08-25-2012 04:39:00
 Re: Farmall 350 starter in reply to gene bender, 08-25-2012 04:26:39
I have had the same issue on my 350u gas rebuild project it happened several times backed off the starter bolts hear the unit click and release. No problems since about twenty five hours on rebuild but always carry wrenches in tool box
