TA valve leak 806
RustyR
Have hydraulic fluid leaking around the shaft that moves up & down when the TA lever is moved. Is this just an unscrew the fitting & new oring/seal deal, or is there more to it? Looks like there are two flats on the fitting around the shaft. Thanks!
