Anonymous-0
I hve a 966 no 4 cylinder scored when looking down cylinder hole noticed brass cooling nozzel in back block hole but front one is open. Do these engines have 2 cooling nozzels or should the front hole have a ball bearing plug in it?
(quoted from post at 21:02:36 07/27/12) I hve a 966 no 4 cylinder scored when looking down cylinder hole noticed brass cooling nozzel in back block hole but front one is open. Do these engines have 2 cooling nozzels or should the front hole have a ball bearing plug in it?
Turbocharged engines use two cooling jets per cylinder, naturally aspirated engines use only one per cylinder.
