SMTA governor
Hayfarmer
I was running a NW pto baler with the SMTA the other day. Hay was heavy and it was running against the governor a lot of the time. Toward the end of the day it acted like it was "tired" would hesitate a little before governor kicked in. Thought it might be getting low on gas so put more in but didn't seem to change it. Any suggestions or do I jusat need to work shorter days?
With out being there to hear and see we are guessing . First make sure that ya have good fuel flow to the carb from the tank. What plugs ya running ?? IF your working the snot out of her ya want a colder heat range plug. Check ing. timing and set at full throttle . Next go up a grade in gas . Open the load screw to 4 1/2 turns to five turns off the seat.
