2640 oil leak
burnsg2003
06-26-2012 20:27:20
Just recently I had to have the injection pump taken off and rebuilt. I did not run the tractor much for a few days after the repair job but since I have used it to cut hay and I have oil dripping down on top of the radiator hose on the left side of the tractor at the front. When they removed the injection pump right by the hose their was cover they had to take off to remove the pump could I be leaking oil there if the cove was not put on correctly. It is engine oil I really can not find anything in that area that should be leaking any thoughts or ideas would be helpful. Thanks in advance for your help.
RPM1941
06-27-2012 10:42:25
 Re: 2640 oil leak in reply to burnsg2003, 06-26-2012 20:27:20
I noticed this post has no answers, 2640 is a John Deere, maybe you should repost on the correct forum.
