WD-9 Drawbars
sflem849
06-19-2012 08:23:14
Here is an update post on 9 series drawbars. We talked about how you never see the same drawbar twice on a 9 series tractor.
This is what the WD-9 book shows as correct for a 9 series with swinging drawbar attatchement.
third party image
Sorry for the iffy picture. I just took a picture of the book rather than scanning it because I am lazy. :?
Red Mercury
06-19-2012 22:04:03
 Re: WD-9 Drawbars in reply to sflem849, 06-19-2012 08:23:14
The drawbar in the picture is exactly what is on all of my WD-9"s and Super WD-9 built between 1951-1955. I have never seen a factory roller type but it sounds like they existed on some tractors. I can also get you some pictures & measurements if you still need them. WD-9"s used to be real common here in Canada and finding the drawbar parts would have been easy at one time (okay, I"m not much help am I?).
sflem849
06-20-2012 04:34:08
 Re: WD-9 Drawbars in reply to Red Mercury, 06-19-2012 22:04:03
There are some parts of the country where they are as thick as Ms around here. There is no reason you need to taunt me about it. :lol:
I could use the measurements if you get a chance. Thanks!
tjv
06-19-2012 20:15:29
the one in this pic makes it a double strap hitch some tractors may have had a roller but then were a single strap i will have to look at our wd 9 tomorrow to see what it has may be able to get measurments for you
sflem849
06-19-2012 15:51:23
Same roller as an M? Similar, but bigger would be my guess.
I think I am going to try to recreate the one in the picture. If anybody has any measurements I would appreciate it.
Harold H
06-19-2012 08:57:26
This is correct on earlier 9 series tractors. Later 9 series swing drawbars were available with a roller rather than the slide, although the slide type was probably available throughout production.
Harold H
