What is this leak on an H?
dstates
I'm still scraping off mud and debris and I noticed a "new to me" leak (I'm sure it has been there a while) on the RH side of the engine behind the distributor. It is the cover on the side of the block with what looks like a cork gasket. [b:69030a44e0]Are these coolant passages under the cover or is this an oil leak?[/b:69030a44e0]
Thanks for your help!
(quoted from post at 04:15:10 06/16/12) Since you have an "H" you should check out this wonderful web site: http://thefarmallh.com/1950_H_Page_1.html
Wow, I would have parted that H out in a heartbeat!
