806 hydraulics
Bob52 Martin
06-03-2012 07:34:58
I have pressure at he two back ports, and the two point works fine, but no pressure at the brakes, steering or clutch.
Is this a symptom of anything fixable.
RPM1941
06-03-2012 08:48:39
 Re: 806 hydraulics in reply to Bob52 Martin, 06-03-2012 07:34:58
Your problem is the front or MCV pump & system in TA/clutch housing, back hyd in rear frame is OK. You could have any of a multitude of things wrong in the MCV, key sheared on pump, blown gasket or o-ring, relief cartridge weak or stuck. These 2 systems draw from the common reservoir of Hytran & filter.
mazemeister
06-03-2012 11:10:49
 Re: 806 hydraulics in reply to RPM1941, 06-03-2012 08:48:39
or could be as simple as the front pump lost its prime. when/how did the problem start?
Bob52 Martin
06-03-2012 11:52:38
 Re: 806 hydraulics in reply to mazemeister, 06-03-2012 11:10:49
I had it stuck in a wet spot and the back of the tractor was tipped down quite a bit. Everything was working when I shut it off.
So I went and got the cat the next morning and pulled it out. Then I had the no hydraulics on the front end of the tractor. If the prime was the problem, how would I fix that?
Bob52 Martin
06-03-2012 08:56:15
Thanks a lot. sounds like I'll be dragging it up here and taking it apart.
bob
Janicholson
06-03-2012 14:12:20
 Re: 806 hydraulics in reply to Bob52 Martin, 06-03-2012 08:56:15
Do not take it apart: Fill the reservoir with 5 gallons of extra Hytran. It covers the air leak and causes no harm (standard operating procedure.) Jim
Bob52 Martin
06-03-2012 14:59:04
 Re: 806 hydraulics in reply to Janicholson, 06-03-2012 14:12:20
I finally wound up with that Jan. I can't thank you guys enough. Here's the whole deal, just in case you need a hillbilly to laugh at - I'll do fine.
I had the problem I described and was piecing together a fix from different posts on the forum. I didn't know what the MVC was, but again wound up at the right part on the tractor. I've had this 806 for 25 years and never had a problem of this type. Tractor's been bullet proof for a long time.
I came up with the over fill from one post, and the bleed on it as being the 5/8 cap on the clutch side, rear of casing below what must be a 1" or 1/8 (about nut).
I overfilled the tranny (which was lower than I thought - my fault) took out the 5/8 cap completely (probably not the thing to do) and used a heater hose to blow air into the tranny case through the fill tube. Started the tractor.
Now a word of advice from someone who now knows -DO NOT STAND IN FRONT OF THAT LITTLE BLEED HOLE WHILE YOU'RE DOING ALL THIS!!
But that's all it took. The prime took hold, sprayed the idiot standing in front of the bleed and now the tractor works fine.
Thanks so much,
Bob
Janicholson
06-03-2012 16:03:30
 Re: 806 hydraulics in reply to Bob52 Martin, 06-03-2012 14:59:04
I am glad there was no major disassembly before the fix was discovered!! I was hoping you haden't torn into it. Jim
Bob52 Martin
06-03-2012 16:50:16
 Re: 806 hydraulics in reply to Janicholson, 06-03-2012 16:03:30
No, Jim. I was just trying to get it figured out. I had no idea what it was, but the fix I was in was pretty obvious. I rely heavily on that 806 - always have.
Lot of relief when it started working again - even with the oil bath I got, lol. Got the field work finished - huge relief.
Thanks for all your help.
Bob
