IH 140 hydaulic oil leaking into motor
ann balch
New User
Got a IH 140 leaking hydraulic oil into motor crank case. It appears to be leaking at the pump, on the right hand side, next to the distributor. has any one had this issue before? If so what has to be done to fix it. I assume there is a seal gone, who knows what else!
Common problem fix the seal. Take the pump off so you can get the correct seal different types of seals and you mite need a speedy sleeve for the worn shaft. You dont know what has been changed over the yrs thats why you want to take the pump apart and with you when you order new parts. Local auto store should be able to get what it needs or go to the dealer.
I needed an o-ring for mine. 2 dealers were no help. They don't have a break-down on those pumps anymore. I got it from a hyd. place & they sent a wrong one first. Second one fit right. Cost me $13 for it.
