cleaning bolts
They do not need HCl. Use parts cleaner (mineral spirits, etc) on the greasy ones then a bench grinder on all as NE Cowman says.
You will not like the results of cleaning bolts with acid. It tends to eat away at thin metal (the threads) and you end up with a bolt that will strip out. I suggest a bench brush. I clean lots of parts with acid, but I do not recommend cleaning bolts or nuts.
Muriatic / Hydrochloric Acid is NOT recommended for bolt cleaning. Use a degreaser of your choice. Clean thoroughly. If the thread looks OK, but needs a little more, use the correct die to chase the threads. I firmly believe there is no substitute for using the right tools for the right job. It saves financial and emotional heartache in the long run.
SadFarmall
another vote for the wire wheel on a bench grinder
every bolt I take out of anything gets turned against the wheel
for a second. turns back in with fingers then
Go in the house and swipe your wife's crock pot(buy her a NEW one) and use Simple Green in that crock pot on "high". Does a GREAT job of home made "hot tank" cleaning
(quoted from post at 15:39:14 05/15/12) Go in the house and swipe your wife's crock pot(buy her a NEW one) and use Simple Green in that crock pot on "high". Does a GREAT job of home made "hot tank" cleaning
Goodwill might be a safer option. I have bought enamal roasters for parts cleaners there. :lol:
If they're rusty or I want them really clean to paint I throw them in a rock tumbler/polisher and let them tumble over night. It's like a low speed sandblaster.
I have cleaned a TON of bolts with a wire wheel on the grinder. I personally would not use a chemical and take a chance of duing something wrong with the chem.
