300U Missing at Low Idle
Mfan
05-06-2012 19:32:37
300 utility, still 6 volt positive ground. New points and plugs, timing set. Runs well at high rpm, good power. When dropping back to low idle, will miss but not in a regular pattern. Idle is set around 500-550 rpm, will stay at that and not die off. Any suggestions?
david G
05-07-2012 13:51:36
 Re: 300U Missing at Low Idle in reply to Mfan, 05-06-2012 19:32:37
I would check the valve clearance, could have one wide.
Janicholson
05-06-2012 20:25:59
If it just pops and flips the rain cap every few seconds it is pretty normal. I would adjust the idle mix and timing to spec, and if it is inconsistent, and as described, leave it alone. Jim
504
05-06-2012 19:58:49
Idle circuit in the carb is plugged. Try Seafoam first before tearing into the carb.
