What model Farmall?
stumpman
What is the smallest/oldest model Farmall that has a hydraulic 3 pt hitch that will pull a 5' set of discs could also handle pulling a 5' rotary cutter. Looking for something old and different to play around with.
Thanks!
Or you can put a 3 point on anything from the C up. An H is better suited for the bush hog, though. The fast hitch on any tractor can be converted to 3 point.
