Vertical distributor
ohio farmer
05-05-2012 19:12:38
Where do you get parts or who repairs delco distributors (#1111411)?
ohio farmer
05-06-2012 09:29:46
 Re: Vertical distributor in reply to ohio farmer, 05-05-2012 19:12:38
Gear on the bottom of distributor is junk
rustyfarmall
05-06-2012 09:52:32
 Re: Vertical distributor in reply to ohio farmer, 05-06-2012 09:29:46
If that gear is junk, the one that drives is probably junk also. Allis-Chalmers, John Deere, and I think Case tractors all use the Delco ignition, so you might be able to find a good, used bottom gear.
gene bender
05-06-2012 05:02:42
You can change to the I-H dist if yours is bad.
wayne in mn
05-05-2012 21:02:24
Auto parts store or Case-IH dealership.
