SH Gasket set Copper washers
Anonymous-0
I just got in my gasket set from YT. I am only using part of these gaskets. I have not removed crank. What are the copper washers for?
Also it has 2 oil pump gaskets they look the same. I only used one.
Randy
The oil pump gaskets give the proper clearance between the gears and the bottom cover. You need to put in the same number you took out, provided the cover is not worn too much, in which case you need to sand it flat or replace it.
