IAtractorKid
Hey guys! Having some issues with my loader on my SH and
hoping you can help me out. Hopefully the pictures show up
clearly but i have an M&W live pump behind the distributor
with 3 spool valve in the loader. 1/2" pressure line from
pump to valve, 1/2" return from spool to loader upright
reservior, 1/2" line from bottom of loader upright reservior to
top of gutted belly pump and 3/4" line from bottom of belly
pump housing to supply side of pump.
Basically when i go to raise the loader, there is a long delay
before the loader moves at all. I know the pump is only 10 or
12 gpm but it seriously takes close to a minute of pulling the
lever back before the loader ever moves. Once it starts
moving it does pretty good unless i stop and then there is the
delay again. Also, when i go to lower the loader, i have to
very carefully as it seems to be dropping and not pressuring
down as it should. So...any ideas?????????
I was thinking i need to replace the 1/2" lines from valve to
reservior and reservior to belly pump with 3/4" to feed the
pump more volume. What do you think???
Sorry for the long post but thanks for the help!
