450 leaking antifreeze
All you should have to do is tighten the jam nut behind the fan blades. Very much like tightening the packing on a water faucet. The nut does not have flats on it just notches and made out of brass. You should be able to use a channel lock pliers to do the job.
What Don says, but add a drop of loctite on the threads. I had
a new water pump that unscrewed itself.
(quoted from post at 18:16:27 04/07/12) All you should have to do is tighten the jam nut behind the fan blades. Very much like tightening the packing on a water faucet. The nut does not have flats on it just notches and made out of brass. You should be able to use a channel lock pliers to do the job.
Cool thanks
As Don said, tighten the packing nut, but only as much as it takes to get it to not leak. Too tight can become a problem also.
Steve
