B valve spec.
JDJACK
I am searching for the intake and exhaust tapped gap specs.
Also are there timing marks or tdc marks anywhere?
14thous when cold. Just start at the front and use the crank till both are open. That way you dont need timing marks. If you remove the plugs it will make turning over easier.
I just did my A yesterday and the manuel said .014 in. warm and was a big difference than when cold, have a happy Easter,stumper
