super c fan assm
Is there a difference between one with a waterpump and one with out? I have seen somnew ones for sale, but they all say without waterpump?? THANKS FOR ANY INFO!!
Yes, the fan assembly is very different for water pump models. The fan blade has a cut out specific for the water pump outlet and the fan is not as aggressive. Also the pulley sizes change from the early SC to the 200 yielding a faster generator turn. Otherwise the fan assembly is functionally identical. I did install one on an SC by switching out the pulleys and the fan blades using the items from the old assembly and it worked fine. The new units have a much better bearing arrangement.
