farmall 350 gas line routeing
F-12 guy
I'm wanting to put a new steel gas line on my 350. Does anyone one have a picture of the route the line takes or a good description of the route so I can try to make the correct bends. I have tried looking at pictures but cannot zoom in close enough. Thanks Josh
A picture or diagram won't help much. I usually have enough problems getting the ones I take off back on. They have to be bent exactly. Perhaps someone has a good used one, if not I would likely use rubber tubing, although I would much rather have an original. Can your old one be repaired? Look at OEM Tractor Parts web site. I don't think they have them but it is worth a look.
