I think it's mostly just the gov. shaft seal. Can that be changed without going into the pump? The first two pictures show the wet place from the shaft down, running along the bottom of the pump, with some dripping onto the frame rail and some running on down the side of the engine block. After a thorough cleaning 8 days ago, then running the engine for an hour or so 6 days ago, then sitting until yesterday, it has done what you see and dripped 4 or 5 drops on the floor. Getting ready for paint, that's enough that I think I want it fixed.
This last picture shows some slightly damp places between one of the covers and the engine block. I don't think this one is bad enough to fix unless it's really, really, easy, or unless someone smarter than me really, really, thinks it should be fixed before paint.
