OK i have a 1950 farmall m 6 volt positive ground that will not charge. Did the motor test on the generator its fine. This tractor has a cutout relay on the generator. This thing will only charge when i ground the generators field to the frame of the tractor. I put a brand new 4 position light switch in with a brand new wire from light switch field resistor to generators field post and still nothing. If i have the field wire hooked up and touch the cutout relay points together all it does is discharge. Im almost ready to just put a grounded wire from the field post on a switch so i can charge it when i need to. Cant quite figure it out.
