I put the H out and let it run for about an hour today after taking the NEW water pump apart to add packing and loctite. It ran great and there are no leaks now.
I did lose the woodruff key for the steering in the mud. I plan to replace the steering shaft and sector gear, so I had the coupling that holds the steering from pulling up loose'nd. I pulled back on the wheel, the key fell to out and I had to get a new key.
