Just got McCormick Deering 15-30 / 22-36 ?
I just saved this tractor this morning, it was at the local scrap yard, it was sitting beside a idling crusher, i luckily was able to buy it from them for only $500, being it weighs over 7000lbs it's not to far from scrap price.
I can't find the number tag? i was thinking it should be on the firewall by the oil gauge?
at first i thought this was a 15-30 but then i noticed the gas tanks are different so now i think it's a 22-36.
One rear rim is junk, the other is on it's way, both front rims are pretty good, missing side panels, and the engine is stuck.
I'm going to get some parts off of it and then sell the left over parts.
I also have another 22-36 that the engine is not stuck.
I made a deal with the scrap yard, and from now on they are going to sell me any tractor that comes in :)
its a 15-30
no water pump, and no oil filter. botht hose items were put on in '29 when the rating was upped to 22-36 even htough serial tags still read '15-30'. the serials for 22's had an M on the end
15-30, it has the zenith carb from a w-30 and the manifold and governor set up. no 15-30's or 22-36 had up right exhuast unless it had the robin manifold.
(quoted from post at 06:30:00 01/27/12) 15-30, it has the zenith carb from a w-30 and the manifold and governor set up. no 15-30's or 22-36 had up right exhuast unless it had the robin manifold.
W-30 wont fit a 15 or a 22. W-30 will only fit on a 10-20
this manifold and carb setup is off a P300 power unit. i used to have a 15-30 with this same setup, good for a few more ponies
ya, ok.i do know that the w-30 and 10-20 is the same and wont bolt to the 15-30 head., but its still a setup found on the w-30 tractors.
Thanks for everyone's help and info.
I am located in Burns, Kansas.
Burns is 60 miles Northeast of Wichita.
you can email me at [email protected]
i can also ship the parts if possible.
Thanks again for everyone's help
