sickle bar mower for a/sa fit c?
soundguy
01-26-2012 18:11:25
hate to ask.. but will a 5' SB mower for a 'A' or a Super 'A' fit a c?
thanks
Jim Becker
01-27-2012 18:29:37
 Re: sickle bar mower for a/sa fit c? in reply to soundguy, 01-26-2012 18:11:25
It won't fit without major work. You'd come closer with one from an H, or even from an F-20.
TWheat
01-27-2012 17:20:39
The mounting "brackets" for the C21 resemble the U draw bar assembly for a C. It bolts over the rear axle tubes. (Very similar to U shaped draw bar on your H)The rest of the frame of the A or SA mower bolts to that bracket assembly, on one side a bolt goes thru both members and pivots and on the other side it's made to break-away.I have one that I can take a picture of that would make it much clearer than what I have described. To backtrack just a bit, this is for the rear mounted mower. Question, why a 5' vs a 6' cutter bar?
TWheat
01-28-2012 05:06:08
 Re: sickle bar mower for a/sa fit c? in reply to TWheat, 01-27-2012 17:20:39
third party image
third party image
OK, I can do it this way.
The mower on the SA came off the frame that mounts on a C, SC.
soundguy
01-27-2012 17:28:30
it's what the guy on craigslist was sellin :)
mkirsch
01-27-2012 05:33:21
If you are talking about a belly mower, no. It will not fit without major modifications.
If you are talking about a rear mount mower, it can be done, but you will need to rig up a horseshoe drawbar for the C.
gene bender
01-27-2012 01:32:05
You will need some brackets as the drawbar from the A and B is different from the C So if youre talking bolt and unbolt no it wont but it would be easy to just make two pieces of iron fit the mower to the Cs drawbar all you need to do is park them side to side
old
01-26-2012 21:29:47
Wish I could help you on that one but since I only have an A with a 6 foot sickle mower I can not say if it will fit or not. Only thing I might be able to do to help would be to measure how wide the mounts are on the rear end of my BA and then you could compare that to your C and of close you might be able to make it work. I do know the draw bar had to be removed to install the mower I have
teddy52food
01-26-2012 18:44:19
I don"t think so.
Zachary Hoyt
01-26-2012 18:20:07
I don't know, but that would be a great mowing tractor I would think, very nimble and maneuverable.
Zach
