Hyd lines on 460 diesel
cih9280
I need to replace the steel hyd. lines under the seat that run the 2pt. hitch. They are not avail.from CIH. Doe's anybody have an idea where I can get the set. The serial # is above 20,000
Thanks for any help. This is a row crop tractor.
I had a hydraulic place make me some new steel ones,using the old ones for a pattern.Worked perfect on my 300 utility, just had to use different fittings.
MARK
You can always get some 5/8 inch tubing, some union fittings, and make them yourself. This is my 340U.
