F-20 frt wheel questions
Eric-IA
Is the spindle the same size if the tractor had spokes or cast frt wheels? I have a good set of cast hubs off a '38 that I would like use to replace a damaged set of spokes.
Thought I would ask before taking them all apart.
Thanks
Regular, F20 and F30 can all use the same wheel.
F30 has a larger diameter felt on the inside so the felt and metal retainer need to be swapped out
