McCormick W6 Seat
LarryM
So bought a W6 and it has a seat similar to the Stage2 Super M through 450. It does not have the battery under it but it is the same suspension. Is this original to a W6 or did someone put it on there off of Super W6? I willnot be back in the shop before Friday so I will post a Pic then.
my1950 W-6 has batt on left side
all W6's have the pan seat that is bolted to the trans cover.
the super W6 in 1954 with the TA will have the seat with the spring under it.
all batt's are located on the left side by trans.
Same set up on AW-6 tractors. On AW-6 Diesel tractors there is a much longer box beside the trans/motor which carries two 6 volt batteries in series.
SadFarmall
