Will 3288 rims fit a 7110?
kennell
A freind of mine grows potatoes. He has two 7110 tractors that he still uses for spraying. He found a set of skinney tires his father had bought for a 3288 they used to own. Will the 88 series rims fit the 7110's? Thanks Kent
If he has the tires and the 7110 he should be able to look at and measure them to see if they are the same style and size of rim.
Gary
The most common rim on a 3288 is a 38" double-bevel style.
If your 7110 has 38" double bevel rims on it now, they will fit.
