Hi All,
We are a little new to the diesel engines so I could use some
help. We have an IH 584 Diesel with a leak coming from the
injector pump. Its a drip that looks like it originates from the
gasket between the pump body and the manifold that distributes
to the injectors. It drips worst when the tractor is not running;
hardly noticeable when it is on. The pump is a bosch va4
10h1150cr 8. Can we just replace the gasket or is this a
symptom of something bigger? Where do we get gaskets? Do
we have to worry about anything else when we open the end of
the pump to replace the gasket?
Thanks for the help!
