Keven McNeice
New User
Hello everyone, Merry Christmas,
I have a Farmall C with electrical issues. It
runs, but will not charge. It has a Magneto and a
Delco-Remy alternator. Not sure if I have to have a distributor for a 12 volt system, but this is how i got the tractor.
I followed the 12 volt
conversion diagram for everything but the wires
that go to and come from the IGN switch, which is
where I followed the 6 Volt Diagram, and left the
Number one terminal alone.
See 12 volt Diagram here:
www.productionfield.com/Extra/05-
See 6 volt Diagram here:
www.productionfield.com/Extra/04-
I was curious if anyone had a suggestion for what
I should do? We have tested to see if it charges
at the alternator, from the Bat terminal to ground
and only got what the battery had (11.95 volts)
Also, the tractor runs at an inconsistent RPM
occasionally. Could that be spark plug problems? I
have replaced the rings, honing the sleeves in the
process. The spark plugs are newer but were used
when I had a busted oil ring on the number 2
cylinder so I will replace them unless someone suggests another approach.
