Hydraulic Problem
Ed Bouws
11-02-2011 18:01:58
1951 Farmall M -- M&W live hydraulic pump with two valve remote control. I am having problems with oil coming out of the vent cap. Any suggestions on how this problem can be resolved? Someone advised me to change the type of oil I am using. I am currently using IH Hy-tran hydraulic oil & still encounter the same issues. Thank you!
mkirsch
11-04-2011 20:27:07
 Re: Hydraulic Problem in reply to Ed Bouws, 11-02-2011 18:01:58
Get a regular pipe cap from the local hardware store and put it on in place of the vented cap.
As I said before, two-way hydraulics are not supposed to have a vented cap.
Ed Bouws
11-04-2011 17:54:20
Yes, it is the belly pump reservoir and I am having troubles without any hydraulic implements hooked up.
mkirsch
11-03-2011 06:38:07
Changing fluid won't make a bit of difference.
You should be using a non-vented cap when you are running two-way hydraulics. The christmas tree two-way valve came with a cap that had a vent you could close for two-way operation.
Also, you may be topping off the reservoir at the wrong time. Make sure you top off the reservoir with any cylinders completely retracted.
It takes more fluid to extend the cylinder than it does to retract, because the cylinder's rod is taking up some of the space inside. When the cylinder is retracted, that will be the point where you will have the maximum amount of fluid in the reservoir.
If you top off the reservoir with the cylinder extended, the excess oil will need to go SOMEWHERE, and that somewhere is out the vent hole.
janicholson
11-02-2011 19:21:29
Solution is easy put the return hose into a "T" and close nipple in the drain of the reservoir(or liftall used as a reservoir) Jim
Mike1972chev
11-02-2011 18:38:55
When you say"vent cap",are you meaning the fill cap on your belly pump reservoir????
Do you have your hydraulic return hose plumbed into the fill tube on your belly pump reservoir???
