Order Farmall Cub Parts Online
cub cadet install help
1965lonewolf
10-28-2011 16:07:38
need pictures and or detailed info on putting a plow on a cub cadet 1250
Stephen McCoy
10-30-2011 07:17:17
 Re: cub cadet install help in reply to 1965lonewolf, 10-28-2011 16:07:38
Try eBay and craigslist. I've had pretty good luck with both.
It wouldn't be very difficult to fabricate one yourself if you have a hacksaw, a drill, and a welder. I've adapted a couple different snow blades to other lawn tractors in the past. Anything is possible.
If you're feeling really ambitious, I can get you detailed measurements from mine.
Stephen McCoy
10-30-2011 06:53:47
I have some Cub Cadet Manuals in PDF format I could send you if that would help.
Off hand I'm wondering if you have a narrow frame blade, the 1250 is a wide frame tractor. That's just a guess of course.
Could be that something is bent as well. I don't recall the difference in width between the narrow and wide frame models but I think it was more than an 1/2".
Is this the blade you have?
third party image
shelley2007
10-30-2011 07:13:40
 Re: cub cadet install help in reply to Stephen McCoy, 10-30-2011 06:53:47
found out i have a narrow frame plow set up and my 1250 is a wide frame, so i'll start looking for a plow frame
El Toro
10-29-2011 16:52:48
Are you using a sleeve hitch? You didn't say snow blade. Hal
1965lonewolf
10-29-2011 17:57:14
 Re: cub cadet install help in reply to El Toro, 10-29-2011 16:52:48
snow blade , but its not wide enough, need to be 1/2 wider on each side
kennell
10-28-2011 20:07:22
Do you mean a rear plow or a snow blade on the front? Kent
1965lonewolf
10-29-2011 17:57:53
 Re: cub cadet install help in reply to kennell, 10-28-2011 20:07:22
