1206 steering
Anonymous-0
I have a 1206 ih farmall. The steering has quit and there is no backpressure to the steering wheel. Changing the filter has had no effect, 3 point, pto, brakes and TA all work fine. any ideas local dealer only has one quy that knows them and he is very hard to contact.
Sounds like your flow divider is stuck.It is up on top of the center section left side between starter and battery kind of a spool with steel lines hooked to it.
