Farmall H M Governor
Eddie Ward
10-11-2011 04:04:43
Will the governor from an H work on an M and if not, will the shaft and weights work in the M housing?
Eddie Ward
10-11-2011 07:39:25
 Re: Farmall H M Governor in reply to Eddie Ward, 10-11-2011 04:04:43
Thanks for the replies, I noticed that the gears have different part numbers and wasn't sure if they have to be changed.
dej(Jed)
10-11-2011 04:44:11
The H tube is shorter than the M tube, so change it out and you are good to go.
sflem849
10-11-2011 04:36:50
They will pretty much work, but there are a few things you have to swap out. Somebody that knows more (or a search) will tell you what you need to swap out.
SadFarmall
10-11-2011 04:31:36
Surely will, the governors are identical.
SadFarmall
