656 front wheel bearing numbers
Hello,
I was wondering if anyone knew the bearing , race , and seal numbers for the inner bearing( larger one) on a 656 narrow front.
Thanks,
YC
Timken numbers--LM603011----LM603049 bearing & race.
This assumes the 656 is the same as 1066. The IH kit which has bearings, seal, gasket, & race fits everything from 560 to 1660 combine & more.
Don't know if seal is avail. from anyplace but IH--it's on the order of $15??--can't remember.
You also get the replacement seal wear sleeve in the IH kit. Remember the kit was around $75--brgs. are lots cheaper by themselves.
