1066 FEL connection
ridgelane
09-05-2011 13:12:31
I would like to know if its possible to tap into the hydraulics of my 1066 with the joystick for my front end loader, without having to use one of the rear remotes.
Aces
09-06-2011 09:02:51
 Re: 1066 FEL connection in reply to ridgelane, 09-05-2011 13:12:31
rideglane. Let me go back to the 706 806. The remote valves under the seat were the same valve for left or right remote, with an end plate. Later on the 756 856 the right hand valve remained the same but the left valve had end plate as part of valve. So if a person needed power beyond as you would like. Then the left valve had to be removed and a new valve was needed so the ports would go through the valve body and the power beyond plate could be added. Maybe could find a good valve off any 706 through 66 tractor if it was right hand valve, but would still need power block. you could email me aschrunk@msn.com
Aces
09-05-2011 17:42:39
ridgelane Yes it is cald a power beyond block, goes under the seat. you will have to change the left valve so as to add the block. Not cheap.
ridgelane
09-05-2011 18:23:33
 Re: 1066 FEL connection in reply to Aces, 09-05-2011 17:42:39
Thanks, but where does this power beyond block connect to and what kind of changes does one need to make to the valve? Is this a bolt on block that is added to the existing valve?
Janicholson
09-05-2011 18:33:53
 Re: 1066 FEL connection in reply to ridgelane, 09-05-2011 18:23:33
The block allows remote valves to be hooked up with tube or hoses. It should have directions on installation if new, or from the previous owner if used. Not complex. Jim
