farmall h temp gauge
Chris S.
08-31-2011 16:17:18
Bought a new temp gauge for the h and i am attempting to take the old brass bushing out of the motor to put the new one in that came with the new gauge. I can"t get the bushing loose for the life of me. Is it possible the bushing is reverse threaded? Thanks!
Chris S.
08-31-2011 20:49:23
 Re: farmall h temp gauge in reply to Chris S., 08-31-2011 16:17:18
I wish i could stay with the original but on the new gauge the insert into the motor bushing is smaller than the current one which is why i was trying to get the original bushing out. I was just assuming that the old and new bushing would be the same size for the hole in the motor. I guess maybe I could go to lowes and see if i can find a bushing to fit inside the original bushing and just leave it. Step up the sizes. Hopefully all the holes would be big enough for everything to fit and it wouldnt be out of the motor to far. Thought a new temp gauge would be a 15min job....oh well just wouldnt be a challenge then!
Dean Olson
08-31-2011 19:30:51
The bushing is a right hand standard 1/2" pipe thread bushing. It's just in there tight. I used a torch, hammer and chisel till I got it out in pieces with out damaging the threads in the head. Have patience and be deliberate.
Tyler Jackson
08-31-2011 18:56:35
third party image
Believe me..... stick with the original if possible. The new brass ones are terrible.
TPU
08-31-2011 17:29:57
Mine has a plug in it, soaked it for weeks, tried some heat on it, but never got it out. Good luck to you.
gene bender
08-31-2011 16:44:57
If you didnt mees up the treads taking the old one out just use it again. It is right hand thread but its been in there for 60 some yrs.
