bjb from Ne in Tx
New User
A cousin of mine gave me this F30 parts tractor so I could have a spare block and clutch parts for my W30. I believe I have all the parts off that I need. What parts should I save as I begin to disassemble it. I don't want to scrap anything that someone might be able to use.
It has the cables, pulleys and springs for the turning brake system. I have the rear clutch cover, transmission, pulley gearbox, rear end (probably some heavy rust on the differential due to some studs missing), gas tank supports and straps, radiator, front pedestal, air cleaner, and steering wheel (on spoke is cracked).
I will be home in Nebraska for the next two weeks. Let me know if you need any F30 parts.
