What is this thing? Hydraulic Proportion Valve
Looks an equal flow splitter with relief provisions. BWDIK. Your guess is pretty much the same thing. It is aftermarket.
Pilot operated check valve.
Hydraulic cylinder will be locked in place until
pressure from tractor activates the spool inside
the control valve. cylinder will not drop with
engine off.
karl f
need to add looks just like a Metro Hydraulics, probably same company. Should be able to google metro, 401, etc. and come up with more info.
karl f
From northern tool
http://www.northerntool.com/shop/tools/category_hyd
raulics+hydraulic-valves+machine-selector-valves
(quoted from post at 05:08:28 08/26/11) From northern tool
From Northern
Pilot operated check valve is designed to lock a cylinder or part of a circuit while a control valve is in neutral position. Double internally pilot operated. Holds circuit at desired pressure while in transport or working. Eliminates replacing worn spools and old valves.
