Matt in MN
New User
Was baling hay, pulling a new to me JD336 baler and my PTO seems to be not working quite right. Not sure if the clutch is slipping or if I have a linkage problem on my 560 Farmall. If I pull the lever to engage PTO back all of the way and hold it there it works great. However, if I let it rest on the tab in the engaged position it starts the baler, then gives up the ghost as soon as any load is put on it. I noticed there looks like some slop in the linkage on the lever and managed to finish the field by jamming a flat head screwdriver in there and worked fine. Should I be looking at some reengineering of the linkage or clutch work?
