Hi all!
I have a "64 IH 140 (6v + ground) with a bad coil. I purchased a new universal 6 volt coil, however it has 3 leads, where my OEM has 4. I figure "-" is common on the new one. If that"s the case then I should wire "-" to the distributor and chassis ground, and wire the ignition switch to "+".
Just wanted someone to confirm this before I make sparks fly
Thanks in advance!
Brady
Thanks in advance!
Brady
