464 International fuel leak
M tractor
I have a 464 International that has a diesel leak from the line right out of the tank and i can not tighten it . Just can not figure how the line is put in there any help would be thankful.
Hi, look at attach parts diagram from caseih.com of 464 Fuel Tank.
Could be that flange on pipe fitting is cracked. If that is the problem then you will have to replace a section of fuel line.
JimB
